If there is any possible way to reduce DSP impact of V2 captures asap… that would be amazing!
The new capture technology is worth the extra hassle. My drives are identical in A/B testing. The problem is now I cannot run my normal number of drives as well as maybe a modulation or tremolo with a compressor in one half of the QC. The device dsp impact is too costly.
I know the new captures are much higher resolution and take up more dsp because you’re basically running multiple v1 snapshots of the device you captured to get an accurate representation in V2, but if there’s anyway to make that package any more compact… PLEASE!! I want to take advantage of the tech but can’t due to its limitations.
