DSP Diagnostics menu
I just got into the settings menu and then DSP Diagnostics (see picture).
What the hell is this? Can I turn off the DSPs or are the on/off buttons only to run the diagnostic program? If I tap on one of the off buttons it turns blue and says ON instead.
The diagnostics menu is specifically used via support when troubleshooting issues with the user.
I wouldn’t recommend changing any settings etc.
Haven’t changed anything, but got a bit terrified when I realized that I probably could turn off the DSPs. :sweat_smile:
LOL I think it’s diagnostic routines you can simply enable / disable but honestly not sure.
