If I take a direct out signal from a Two Notes Captor (no IR) and then monitor with a QC cabinet block, do I need to disable that block before capture?
In other words, will it be capturing the IR as well?
Hi @jtexas, only the signal you are capturing will become the saved capture. The only way a cab or IR would be included is if it were baked in during the capture. Since you are using the Two Notes for the signal without IR/cab etc., it would not be included within your capture.
Perfect. Thank you!
Glad to help! Enjoy!
