Can''t send wet signal to my computer via USB as I only use Output 1 in my presets
My Quad has been set up as follows for live use: Input 1: GTR > Output 1 Mono > FRFR > FOH, Input 2: Vocals > Output 2 FOH.
ALL my presets are like this, and I wanted to do some EQ checking on my laptop with the wet signals coming in. But no matter what I do, I can only ever get my dry signal coming out of my quad cortex into my MacBook. It’s really odd. And quite annoying as it works if I change the output settings to multi out obviously, but I don’t want to do that for all my presets. Any ideas or work arounds?
Hello… To get the wet signal out of the QC it’s usb3/4 out on the grid into your daw? Try that and see if it works… I think that’s maybe what your missing… You also mite need the adjust the audio settings on your mac to match…
I had the same issue. basically to hear the sounds from the QC, you need to set the input to 3 in your DAW.
