Cannot import plugin user presets into Quad Cortex
I’m using Quad Cortex 4.1.0 and same version of Cortex Control and cannot import my user presets from the Mac plugins. I can load default and other presets from the plugin on my MacBook Pro, but it does not work with my user presets.
Trying to load my user plugins from my MacBook I always get the error message that the preset cannot be loaded. I tried it via finder dialog and drag & drop – both ways do not work. All factory presets do not make any problems.
I tried it with my presets of Plini X and Rabea X – both plugins with latest updates … Does anyone have any suggestions how to solve the problem?
Oooh, no reply … Did no-one try it out on its own rig?
My USB is dead or I would have tested it by now. I should have access to another unit tmw, I’ll check it then
I would appreciate your support!
Go to ‘/Library/Audio/Presets/Neural DSP/Plini/User’ on your Mac to see your user presets, then in Cortex Control => Directory go on the left to Plugin Presets, Archetype: Plini X/User and drag your files there. Works here :slight_smile:
