Yeah, I’ve been one of the biggest critics of Fractal’s pitch-shifting over the years, mainly because I used it all the time as the guitarist in my band. At one point a couple years ago, Cliff “shadow fixed” it on the FM3; didn’t mention it, but it was suddenly better - he eventually did admit that it was worked on/improved for that update, but that’s the first thing I would check after every update.
That said, as I’ve said before, in a full-band context, it’s perfectly usable; probably on bass, too, but with as much solo-practice as I do, it leaves a lot to be desired unless you’re playing with overdrive. I never had this issue with my QC, and I knew the QC’s pitch-shifting would be good because I used it all the time on the plugins, so kicking it on on the QC felt normal. I know it’s technically monophonic, but it plays my whole guitar just fine and, more importantly, my bass sounds great through it and has less latency than the Fractal. I have one preset where the Transpose is down 5 semitones, simulating a 5-string, and it feel/sounds almost as natural as playing a 5-string.
Interestingly enough, while many praise the Helix’s poly capo, especially since it was designed by the people who made the Digitech Drop, I was underwhelmed. It’s better than Fractal, for sure, but not as good as QC, IMO. But I used to just use the “Simple Pitch” block and when I switched over to bass, I continued to use this block instead of the poly capo - sure, you’re generally not playing enough notes to necessitate a polyphonic pitch shifter, but it still sounded better to my ears and took up far less CPU. I thought Helix’s Simple Pitch was a better poly pitch shifter even for guitar than Fractal’s Virtual Capo. The big thing about Transpose in the QC, though, is you can go up OR down (which you can’t do with the Drop) and, most importantly, it doesn’t eat all of the DSP. We play Soundgarden’s “Black Hole Sun” and that requires a Transpose +1 and then a Pitch block dropping 25 cents. I can have both of these pitch blocks on and still have plenty of DSP left over for my main sound and effects.
In any case, in a full band, all of the available options will work just fine, but I would just warn others that for solo practice, you’re not going to get much better than the QC. Now, if you’ve tried all the others and feel the QC is sub par, then we’ll just have to agree to disagree
