Hey folks,
Weird one perhapse but comes up a lot for me.
I build a lot of patches with multiple paths for mixing signals between lanes using things like the gain/volume blocks and the lane splitter feature using the mix knob. For instance I capture and create a lot of acoustic IR patches for artists i work with who use acoustics in their set.
These often need tweaking every night to suit rooms and PAs. Usually the only tweak however would be how much mix I want between clean DI signal and processed signal for instance to tame certain frequencies or to compromise between realism and feedback resistance.
It would be amazing if a footswitch, instead of being either a scene or pedal on off, could be assigned as a macro controller, so that on patch A (Acoustic A IR Microphone simulator + processing for instance) at soundcheck a knob in the gig view can be an always active mix between processed and unprocessed signal (Assigned to control mix between lane A and Lane B of the lane split).
I’m sure this could have a million cool uses. We could assign them so we can adjust drive settings etc on the fly with the feet.
In love with my unit however and thanks so much for your time.
all the best
chris
